[GRASS-dev] Makefile: error.log vs. $(ERRORLOG)
Ivan Shmakov
ivan at theory.asu.ru
Tue Apr 1 09:35:28 EDT 2008
May I suggest the following patch?
; Emacs Lisp: (replace-string "$(GRASS_HOME)/error.log" "$(ERRORLOG)")
Makefile (default): Use the `ERRORLOG' variable instead of constructing
the filename manually.
(libsclean): Likewise.
diff --git a/Makefile b/Makefile
index dbf30ff..2eb800b 100644
--- a/Makefile
+++ b/Makefile
@@ -79,11 +79,11 @@ BIN_DIST_FILES = $(FILES) \
scripts
default: builddemolocation
- @echo "GRASS GIS compilation log" > $(GRASS_HOME)/error.log
- @echo "-------------------------" >> $(GRASS_HOME)/error.log
- @echo "Started compilation: `date`" >> $(GRASS_HOME)/error.log
- @echo "--" >> $(GRASS_HOME)/error.log
- @echo "Errors in:" >> $(GRASS_HOME)/error.log
+ @echo "GRASS GIS compilation log" > $(ERRORLOG)
+ @echo "-------------------------" >> $(ERRORLOG)
+ @echo "Started compilation: `date`" >> $(ERRORLOG)
+ @echo "--" >> $(ERRORLOG)
+ @echo "Errors in:" >> $(ERRORLOG)
chmod 744 install-sh
@list='$(SUBDIRS)'; \
for subdir in $$list; do \
@@ -93,19 +93,19 @@ default: builddemolocation
-cp -f $(FILES) ${ARCH_DISTDIR}/
-cp -f ${ARCH_BINDIR}/grass${GRASS_VERSION_MAJOR}${GRASS_VERSION_MINOR} ${ARCH_DISTDIR}/grass${GRASS_VERSION_MAJOR}${GRASS_VERSION_MINOR}.tmp
@(cd tools ; sh -c "./build_html_index.sh")
- @if [ `cat "$(GRASS_HOME)/error.log" | wc -l` -gt 5 ] ; then \
- echo "--" >> $(GRASS_HOME)/error.log ; \
- echo "In case of errors please change into the directory with error and run 'make'." >> $(GRASS_HOME)/error.log ; \
- echo "If you get multiple errors, you need to deal with them in the order they" >> $(GRASS_HOME)/error.log ; \
- echo "appear in the error log. If you get an error building a library, you will" >> $(GRASS_HOME)/error.log ; \
- echo "also get errors from anything which uses the library." >> $(GRASS_HOME)/error.log ; \
+ @if [ `cat "$(ERRORLOG)" | wc -l` -gt 5 ] ; then \
+ echo "--" >> $(ERRORLOG) ; \
+ echo "In case of errors please change into the directory with error and run 'make'." >> $(ERRORLOG) ; \
+ echo "If you get multiple errors, you need to deal with them in the order they" >> $(ERRORLOG) ; \
+ echo "appear in the error log. If you get an error building a library, you will" >> $(ERRORLOG) ; \
+ echo "also get errors from anything which uses the library." >> $(ERRORLOG) ; \
else \
- echo "No errors detected." >> $(GRASS_HOME)/error.log ; \
+ echo "No errors detected." >> $(ERRORLOG) ; \
fi
- @echo "Finished compilation: `date`" >> $(GRASS_HOME)/error.log
- @cat $(GRASS_HOME)/error.log
- @if [ `cat "$(GRASS_HOME)/error.log" | wc -l` -gt 8 ] ; then false ; else true ; fi
+ @echo "Finished compilation: `date`" >> $(ERRORLOG)
+ @cat $(ERRORLOG)
+ @if [ `cat "$(ERRORLOG)" | wc -l` -gt 8 ] ; then false ; else true ; fi
LIBDIRS = \
lib/external/shapelib \
@@ -181,7 +181,7 @@ libsclean: cleandistdirs
distclean: clean
-rm -f config.cache config.log config.status config.status.${ARCH} 2>/dev/null
- -rm -f ChangeLog ChangeLog.bak error.log grass.pc
+ -rm -f ChangeLog ChangeLog.bak $(ERRORLOG) grass.pc
-rm -f include/config.h include/version.h include/winname.h include/Make/Grass.make include/Make/Platform.make 2>/dev/null
-rm -f swig/perl/Makefile.PL swig/perl2/make.pl swig/python/Makefile 2>/dev/null
