[GRASS-dev] Re: Makefile: error.log vs. $(ERRORLOG)
Ivan Shmakov ivan at theory.asu.ru
Wed Apr 9 06:06:27 EDT 2008
>>>>> Ivan Shmakov <ivan at theory.asu.ru> writes:
 > May I suggest the following patch?
 > ; Emacs Lisp: (replace-string "$(GRASS_HOME)/error.log"
 > ;                             "$(ERRORLOG)")
 > Makefile (default): Use the `ERRORLOG' variable instead of
 > constructing the filename manually.
 > (libsclean): Likewise.
	Since there were no objections, I've committed the change.
http://trac.osgeo.org/grass/changeset/30911
