[GRASS-dev] g.mapsets revision 30712
Markus Neteler OSGeo neteler at osgeo.org
Fri Apr 4 16:58:04 EDT 2008
Glynn Clements wrote:
> 	r30712 | martinl | 2008-03-24 11:19:11 +0000 (Mon, 24 Mar 2008) | 2 lines
> 	g.mapsets: (cosmetics) message cleaning, some minor changes in manual,
> tcl/tk-related code removed
> Presumably g.mapsets.tcl should be removed, now that it is no longer
> used.
The CMD line version of g.mapsets is lacking a parameter to
remove (multiple) mapsets from the search path.
This should be added before removing the Tcl version.
I tried but got lost in the tokenizer.
Markus
View this message in context: http://www.nabble.com/g.mapsets-revision-30712-tp16273660p16499199.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
