[GRASS-dev] g.mapsets revision 30712
Martin Landa
landa.martin at gmail.com
Fri Apr 4 17:59:19 EDT 2008
2008/4/4, Markus Neteler OSGeo <neteler at osgeo.org>:
> > r30712 | martinl | 2008-03-24 11:19:11 +0000 (Mon, 24 Mar 2008) | 2 lines
> > g.mapsets: (cosmetics) message cleaning, some minor changes in manual,
> > tcl/tk-related code removed
Glynn:
> > Presumably g.mapsets.tcl should be removed, now that it is no longer
> > used.
> The CMD line version of g.mapsets is lacking a parameter to
> remove (multiple) mapsets from the search path.
> This should be added before removing the Tcl version.
> I tried but got lost in the tokenizer.
try the attached patch (for review), Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
Type: text/x-diff
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20080404/0aad47d8/g-mapsets-del.bin
