[GRASS-dev] g.mapsets revision 30712
Glynn Clements
glynn at gclements.plus.com
Fri Apr 4 19:16:13 EDT 2008
Martin Landa wrote:
> 2008/4/4, Markus Neteler OSGeo <neteler at osgeo.org>:
> > > r30712 | martinl | 2008-03-24 11:19:11 +0000 (Mon, 24 Mar 2008) | 2 lines
> > > g.mapsets: (cosmetics) message cleaning, some minor changes in manual,
> > > tcl/tk-related code removed
> Glynn:
> > > Presumably g.mapsets.tcl should be removed, now that it is no longer
> > > used.
> > The CMD line version of g.mapsets is lacking a parameter to
> > remove (multiple) mapsets from the search path.
> > This should be added before removing the Tcl version.
> > I tried but got lost in the tokenizer.
> try the attached patch (for review), Martin
I should probably have read this message before going ahead and making
my own patch as soon as I read Markus' message.
FWIW:
> + opt3->key = "delmapset" ;
I was going to call the option that, then decided that "remove" is
more accurate than "delete".
Also, I'm not sure what the policy is (or even if there is a policy)
on using abbreviations in option names. For a single word, it's normal
to used the complete word, as option names can be abbreviated. For
multiple words, it's more awkward.
If it wasn't for the fact that addmapset= already exists, it would
have been better to just have add= and remove= (or delete=). The
"mapset" in the option names is redundant, IMHO.
In the end, I went for removemapset=. For interactive command-line
use, I would expect the user to abbreviate it to "rem=" anyhow.
> + tokens = G_tokenize (opt3->answer, ",");
This isn't necessary. When ->multiple == YES, the parser will split
the ->answer string into components which are stored in the ->answers
array (see the code for the other options).
> + G_verbose_message(_("Mapset <%s> removed from search path"),
> + oldname);
If this is desirable, should the addmapset= option have something
similar?
