[GRASS-dev] Re: [GRASS GIS] #117: r.digit fails if launched from
menu
trac at osgeo.org
Fri Apr 4 21:26:04 EDT 2008
#117: r.digit fails if launched from menu
Reporter: 4everskiff | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.3.0
Component: default | Version: 6.3.0 RCs
Resolution: | Keywords:
Comment (by hamish):
I changed grass-xterm-wrapper to automatically look for rxvt if xterm is
not there (r30863)*, but I have zero idea at all how grass-xterm-wrapper
should be handled for native MS Windows installs (but guarantee-xmon is
useless there anyway, as there is no xmons, so don't bother?).
[*] add others as needed (eterm?). I added only rxvt because that's all I
use; xterm is no longer installed by default on Debian.
note r.digit is just a simple front end to r.in.poly, which uses an ascii
format very similar to v.in.ascii's format=standard. Thus creating a new
wxPython raster digitizer to replace the old r.digit should not be /that/
much work.
IMO using r.in.poly is a slightly better approach than v.digit+v.to.rast,
although the latter happening for the backend wouldn't be so bad if it
could be automated.
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/117#comment:4>
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
