[GRASS-dev] Re: [GRASS GIS] #110: db/drivers/dbf fail to build due to undefined reference to 'SASetupDefaultHooks' (SHAPELIB)
GRASS GIS trac at osgeo.org
Fri Apr 11 05:58:44 EDT 2008
  Reporter:  marisn    |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect    |      Status:  new
  Priority:  critical  |   Milestone:  6.4.0
 Component:  default   |     Version:  svn-trunk
Resolution:            |    Keywords:  dbf
Comment (by neteler):
 As suggested by Frank, I have added safileio.c:
 http://trac.osgeo.org/grass/changeset/30934
 If I now remove the GDAL dependency from db/driver/dbf/Makefile it does
 not compile. If I keep it, it compiles. Problem solved?
 Markus
 On Wed, Apr 9, 2008 at 7:01 PM, Frank Warmerdam <warmerdam pobox.com>
 wrote:
 >  Folks,
 >  I'm just trying to catch up on this topic.  There is already a stdio
 >  based implementation in shapelib itself.  I have attached it,and it is
 >  normally in a file called safileio.c.
 >  I'm afraid I'm uncertain of the implications of mixing the Shapelib 1.3
 >  code with GDAL's using Shapelib 1.2.  It seems potentially like it
 could
 >  be a problem.
Ticket URL: <http://trac.osgeo.org/grass/ticket/110#comment:9>
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
