[GRASS-dev] Re: [GRASS GIS] #110: db/drivers/dbf fail to build due
to undefined reference to 'SASetupDefaultHooks' (SHAPELIB)
Glynn Clements
glynn at gclements.plus.com
Fri Apr 11 14:32:01 EDT 2008
GRASS GIS wrote:
> #110: db/drivers/dbf fail to build due to undefined reference to
> Reporter: marisn | Owner: grass-dev at lists.osgeo.org
> Type: defect | Status: new
> Priority: critical | Milestone: 6.4.0
> Component: default | Version: svn-trunk
> Resolution: | Keywords: dbf
> Comment (by neteler):
> As suggested by Frank, I have added safileio.c:
> http://trac.osgeo.org/grass/changeset/30934
> If I now remove the GDAL dependency from db/driver/dbf/Makefile it does
> not compile. If I keep it, it compiles. Problem solved?
Nope.
First, the Makefile doesn't actually compile safileio.c.
Once that's fixed (remove the LIB_OBJS setting), you get an error
because safileio.c is out of sync with shapefil.h:
safileio.c:185: error: structure has no member named `Remove'
safileio.c:188: error: structure has no member named `Atof'
Synchronising the versions of those two files should eliminate the
problem.
