[GRASS-dev] Re: [GRASS GIS] #110: db/drivers/dbf fail to build due to undefined reference to 'SASetupDefaultHooks' (SHAPELIB)
Sat Apr 12 16:51:47 EDT 2008
> >   Reporter:  marisn    |       Owner:  grass-dev at lists.osgeo.org
> >       Type:  defect    |      Status:  new
> >   Priority:  critical  |   Milestone:  6.4.0
> >  Component:  default   |     Version:  svn-trunk
> > Resolution:            |    Keywords:  dbf
> > Comment (by neteler):
> >  As suggested by Frank, I have added safileio.c:
> >  http://trac.osgeo.org/grass/changeset/30934
> >  If I now remove the GDAL dependency from db/driver/dbf/Makefile it does
> >  not compile. If I keep it, it compiles. Problem solved?
> Nope.
> First, the Makefile doesn't actually compile safileio.c.
> Once that's fixed (remove the LIB_OBJS setting), you get an error
> because safileio.c is out of sync with shapefil.h:
> 	safileio.c:185: error: structure has no member named `Remove'
> 	safileio.c:188: error: structure has no member named `Atof'
> Synchronising the versions of those two files should eliminate the
> problem.
I've committed a temporary fix for this; however, it involved manually
fixing safileio.c to be compatible with shapefil.h. It would be
preferable to use matching versions of the original GDAL files.
