[GRASS-dev] Re: [GRASS GIS] #37: r.in.xyz increase region based on input data
GRASS GIS trac at osgeo.org
Fri Apr 11 06:16:11 EDT 2008
  Reporter:  marisn       |       Owner:  hamish
      Type:  enhancement  |      Status:  reopened
  Priority:  minor        |   Milestone:  6.4.0
 Component:  default      |     Version:  unspecified
Resolution:               |    Keywords:
Comment (by neteler):
 I post again to trac:
 Real world example which will a problem for the average user:
 GRASS 6.3.0svn (pat): > r.in.xyz d325095655/p325099657.txt
 out=`basename d325095655/p325099657.txt` fs=space
 Scanning data ...
 Writing to map ...
  100%
 r.in.xyz complete. 0 points found in region.
 (yes, there are points in the file)
 All GRASS import programs actually import the map without the need
 that the user defines the boundary. Here, the user has to preset the
 region
 (extra step) and then s/he can import.
 Since we cannot change to much in GRASS 6, a flag to avoid this extra step
 would be nice, something like:
 -e Scan data file and import complete map
 I am asking because I have to process *many* maps. Sure, I can easily
 write a shell script for that but other users maybe not. Also for the sake
 of consistency... or rename the module which doesn't make much sense.
 Markus
Ticket URL: <http://trac.osgeo.org/grass/ticket/37#comment:9>
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
