[GRASS-dev] Re: [GRASS GIS] #123: r.in.xyz: import bug when using scanned extent
GRASS GIS trac at osgeo.org
Sat Apr 12 09:36:54 EDT 2008
  Reporter:  neteler  |       Owner:  hamish
      Type:  defect   |      Status:  assigned
  Priority:  major    |   Milestone:  6.4.0
 Component:  default  |     Version:  svn-trunk
Resolution:           |    Keywords:
Comment (by neteler):
 Hamish,
 if you look at the original report:
 I use the scan option to get the region. Using that I lose points. Looks
 like a
 precision bug to me (my user hat on). As you can see in my original
 report, I
 also used -a for g.region which doesn't make much sense to me if we
 provide
 the scan option for creating the g.region parameter string.
 Dev hat on I hope that we find a solution for the situation described in
 "Filtering".
 thanks,
 Markus
Ticket URL: <http://trac.osgeo.org/grass/ticket/123#comment:7>
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
