[GRASS-dev] Re: [GRASS GIS] #110: db/drivers/dbf fail to build due
to undefined reference to 'SASetupDefaultHooks' (SHAPELIB)
trac at osgeo.org
Sat Apr 12 17:03:30 EDT 2008
#110: db/drivers/dbf fail to build due to undefined reference to
Reporter: marisn | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: critical | Milestone: 6.4.0
Component: default | Version: svn-trunk
Resolution: | Keywords: dbf
Comment (by rouault):
In the Valgrind log, it's clear that it was the GDAL's SASetupDefaultHooks
version that was used. I guess that if things are right now with GRASS
r30956, it's because safileio.c has been added to the GRASS tree now, and
that its SASetupDefaultHooks version that is used now.
However, it's really risky to have a library 'A', namely GRASS, that
contains SHAPELIB symbols and that links with another library 'B', namely
GDAL, that also contains SHAPELIB symbols...
I'm not sure there's a guarantee that the symbols that will be used will
come entirely from library 'A' or entirely from library 'B'. I'd be afraid
that there's a mix... And here, you really want that the GRASS DBF driver
uses its SHAPELIB symbols, not the GDAL ones.
To be really safe, I would recommend a change to SHAPELIB to add
decoration to all its symbols, like that
#ifndef SHAPELIBDECORATE
#define SHAPELIBDECORATE(x) x
#endif
DBFHandle SHPAPI_CALL
SHAPELIBDECORATE(DBFOpen)( const char * pszDBFFile, const char *
pszAccess );
SHAPELIBDECORATE(DBFOpenLL) ( const char * pszDBFFile, const char *
pszAccess,
SAHooks *psHooks );
SHAPELIBDECORATE(DBFCreate) ( const char * pszDBFFile );
SHAPELIBDECORATE(DBFCreateLL)( const char * pszDBFFile, SAHooks
*psHooks );
int SHPAPI_CALL
SHAPELIBDECORATE(DBFGetFieldCount)( DBFHandle psDBF );
int SHPAPI_CALL
SHAPELIBDECORATE(DBFGetRecordCount) ( DBFHandle psDBF );
int SHPAPI_CALL
SHAPELIBDECORATE(DBFAddField) ( DBFHandle hDBF, const char *
pszFieldName,
DBFFieldType eType, int nWidth, int nDecimals );
The shapelib included within GDAL would be compiled with :
#define SHAPELIBDECORATE(x) GDAL##x
The shapelib included within GRASS would be compiled with :
#define SHAPELIBDECORATE(x) GRASS##x
That's a rather heavy and boring change to SHAPELIB headers and sources,
and to GRASS and GDAL source code, but that would solve definitely the
problems.
(Side node, we should do the samething in GDAL with libtiff...)
Ticket URL: <http://trac.osgeo.org/grass/ticket/110#comment:15>
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
