[GRASS-dev] Re: [GRASS GIS] #110: db/drivers/dbf fail to build due
to undefined reference to 'SASetupDefaultHooks' (SHAPELIB)
Glynn Clements
glynn at gclements.plus.com
Sat Apr 12 19:54:32 EDT 2008
GRASS GIS wrote:
> #110: db/drivers/dbf fail to build due to undefined reference to
> Reporter: marisn | Owner: grass-dev at lists.osgeo.org
> Type: defect | Status: new
> Priority: critical | Milestone: 6.4.0
> Component: default | Version: svn-trunk
> Resolution: | Keywords: dbf
> Comment (by rouault):
> In the Valgrind log, it's clear that it was the GDAL's SASetupDefaultHooks
> version that was used. I guess that if things are right now with GRASS
> r30956, it's because safileio.c has been added to the GRASS tree now, and
> that its SASetupDefaultHooks version that is used now.
> However, it's really risky to have a library 'A', namely GRASS, that
> contains SHAPELIB symbols and that links with another library 'B', namely
> GDAL, that also contains SHAPELIB symbols...
The DBF driver isn't linked against GDAL any more, so this shouldn't
be an issue.
There could be a problem if you use shapelib in some other library or
executable which *is* linked against GDAL but, right now, shapelib is
only used by the DBF driver.
