[GRASS-dev] Re: [GRASS GIS] #110: db/drivers/dbf fail to build due to undefined reference to 'SASetupDefaultHooks' (SHAPELIB)
GRASS GIS trac at osgeo.org
Sun Apr 13 01:57:52 EDT 2008
  Reporter:  marisn    |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect    |      Status:  new
  Priority:  critical  |   Milestone:  6.4.0
 Component:  default   |     Version:  svn-trunk
Resolution:            |    Keywords:  dbf
Comment (by neteler):
 [please respond in trac, grass-dev cannot post to trac]
 On Sun, Apr 13, 2008 at 1:54 AM, Glynn Clements <glynn at gclements.plus.com>
 wrote:
 >  > Comment (by rouault):
 >  >  In the Valgrind log, it's clear that it was the GDAL's
 SASetupDefaultHooks
 >  >  version that was used. I guess that if things are right now with
 >  >  r30956, it's because safileio.c has been added to the GRASS tree
 now, and
 >  >  that its SASetupDefaultHooks version that is used now.
 >  >  However, it's really risky to have a library 'A', namely GRASS, that
 >  >  contains SHAPELIB symbols and that links with another library 'B',
 namely
 >  >  GDAL, that also contains SHAPELIB symbols...
 >  The DBF driver isn't linked against GDAL any more, so this shouldn't
 >  be an issue.
 >  There could be a problem if you use shapelib in some other library or
 >  executable which *is* linked against GDAL but, right now, shapelib is
 >  only used by the DBF driver.
Ticket URL: <http://trac.osgeo.org/grass/ticket/110#comment:17>
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
