[GRASS-dev] SVN error in Add-Ons
Mon Apr 14 21:16:25 EDT 2008
Yann Chemin wrote:
> I tried a fresh check out and it seems that it runs into the same problem...
> # svn co https://svn.osgeo.org/grass/grass-addons/
> svn: Unrecognized URL scheme for 'https://svn.osgeo.org/grass/grass-addons'
> I suppose that svn got allergic to https as you suggested, but I did
> not see that subversion got upgraded recently in my box... Definitely
> not while I was working.
Note that the svn libraries rely upon the Neon library for HTTP/WebDAV
access, which in turn relies upon OpenSSL for SSL.
It's possible that the problem could be caused by an update to either
of those libraries, or a configuration change for OpenSSL (Neon
doesn't appear to have any configuration).
