[GRASS-dev] SVN error in Add-Ons
Yann Chemin
yann.chemin at gmail.com
Mon Apr 14 21:18:37 EDT 2008
OK,
that must be something in this line that happened,
I do not record all the time if such software gets upgraded.
I'll check that up after work today,
Thanks for the help !
Yann
On 15/04/2008, Glynn Clements <glynn at gclements.plus.com> wrote:
> Yann Chemin wrote:
> > I tried a fresh check out and it seems that it runs into the same problem...
> > # svn co https://svn.osgeo.org/grass/grass-addons/
> > svn: Unrecognized URL scheme for 'https://svn.osgeo.org/grass/grass-addons'
> > I suppose that svn got allergic to https as you suggested, but I did
> > not see that subversion got upgraded recently in my box... Definitely
> > not while I was working.
> Note that the svn libraries rely upon the Neon library for HTTP/WebDAV
> access, which in turn relies upon OpenSSL for SSL.
> It's possible that the problem could be caused by an update to either
> of those libraries, or a configuration change for OpenSSL (Neon
> doesn't appear to have any configuration).
Yann Chemin
International Rice Research Institute
Office: http://www.irri.org/gis
Perso: http://www.freewebs.com/ychemin
