[GRASS-dev] Re: [GRASS GIS] #110: db/drivers/dbf fail to build due to undefined reference to 'SASetupDefaultHooks' (SHAPELIB)
GRASS GIS trac at osgeo.org
Tue Apr 15 11:26:51 EDT 2008
  Reporter:  marisn    |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect    |      Status:  new
  Priority:  critical  |   Milestone:  6.4.0
 Component:  default   |     Version:  svn-trunk
Resolution:            |    Keywords:  dbf
Comment (by neteler):
 Maris, William, is the problem solved (for now)?
 Question: Can we remove the Shapelib copy and use only GDAL/OGR for this?
 The needed functions are
 nm /home/neteler/grass63/dist.x86_64-unknown-linux-gnu/driver/db/dbf |
 grep DBF
                  U DBFAddField
                  U DBFClose
                  U DBFCreate
                  U DBFGetFieldCount
                  U DBFGetFieldInfo
                  U DBFGetRecordCount
                  U DBFIsAttributeNULL
                  U DBFOpen
                  U DBFReadDoubleAttribute
                  U DBFReadIntegerAttribute
                  U DBFReadStringAttribute
                  U DBFWriteDoubleAttribute
                  U DBFWriteIntegerAttribute
                  U DBFWriteNULLAttribute
                  U DBFWriteStringAttribute
 In GDAL/OGR, the AVC driver uses DBF bindings:
 gdal/ogr/ogrsf_frmts/avc/
 There is a local copy of dbfopen.h. Perhaps we can do the same?
 Markus
Ticket URL: <http://trac.osgeo.org/grass/ticket/110#comment:18>
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
