[GRASS-dev] [GRASS GIS] #126: v.outlier & sqlite
GRASS GIS trac at osgeo.org
Tue Apr 15 11:42:17 EDT 2008
 Reporter:  dadudeman         |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect            |      Status:  new
 Priority:  major             |   Milestone:  6.4.0
Component:  default           |     Version:  6.2.3
 Keywords:  v.outlier sqlite  |
 When running v.outlier with sqlite.db, I encounter the following error.
 DBMI-SQLite driver error:
 Error in sqlite3_prepare():
 no such table: Auxiliar_outlier_table
 ERROR: Impossible to write in the database
 Google revealed a page that identified the same problem with a solution.
 http://lists.osgeo.org/pipermail/grass-user/2006-November/037304.html
 When I increased the spline step parameter, it worked (or at least it ran
 a while, I am unable to verify my results yet).  I was unable to change my
 region resolution, so I kept increasing the spline step until it would
 run.
Ticket URL: <http://trac.osgeo.org/grass/ticket/126>
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
