[GRASS-dev] G_OPT_R_OUTPUT base or output?
Roger Bivand
Roger.Bivand at nhh.no
Wed Apr 16 10:47:45 EDT 2008
On Wed, 16 Apr 2008, Dylan Beaudette wrote:
> On Wed, Apr 16, 2008 at 7:26 AM, Roger Bivand <Roger.Bivand at nhh.no> wrote:
>> On two very similar systems built today from the RC6 tarball (i686 RHEL5,
>> F7), I see that G_OPT_R_OUTPUT gets defined on F7 as "base", and the
>> traditional "output" on RHEL5. The tarballs have the same md5sums. Why?
>> r.in.gdal, r.in.ascii, r.los and r.in.bin (at least) are affected.
>> lib/gis/parser.c sets Opt->key to "output" in both, and G_OPT_R_BASE is a
>> different entry in the enum definition. I find this puzzling ...
>> Roger
> Hi Roger,
> Did you do a:
> make distclean
> before compiling the source?
I used the tarball, and untarred to a fresh directory. Should I still have
said make distclean? I'll try - but why the different behaviour? The
windows native binary is "output".
Best wishes,
Roger
> Cheers,
> Dylan
>> Roger Bivand
>> Economic Geography Section, Department of Economics, Norwegian School of
>> Economics and Business Administration, Helleveien 30, N-5045 Bergen,
>> Norway. voice: +47 55 95 93 55; fax +47 55 95 95 43
>> e-mail: Roger.Bivand at nhh.no
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
Roger Bivand
