[GRASS-dev] G_OPT_R_OUTPUT base or output?
Dylan Beaudette dylan.beaudette at gmail.com
Wed Apr 16 10:54:47 EDT 2008
On Wed, Apr 16, 2008 at 7:47 AM, Roger Bivand <Roger.Bivand at nhh.no> wrote:
> On Wed, 16 Apr 2008, Dylan Beaudette wrote:
> > On Wed, Apr 16, 2008 at 7:26 AM, Roger Bivand <Roger.Bivand at nhh.no> wrote:
> > > On two very similar systems built today from the RC6 tarball (i686
> RHEL5,
> > > F7), I see that G_OPT_R_OUTPUT gets defined on F7 as "base", and the
> > > traditional "output" on RHEL5. The tarballs have the same md5sums. Why?
> > >  r.in.gdal, r.in.ascii, r.los and r.in.bin (at least) are affected.
> > >  lib/gis/parser.c sets Opt->key to "output" in both, and G_OPT_R_BASE is
> a
> > > different entry in the enum definition. I find this puzzling ...
> > >  Roger
> > Hi Roger,
> > Did you do a:
> > make distclean
> > before compiling the source?
>  Hi,
>  I used the tarball, and untarred to a fresh directory. Should I still have
> said make distclean? I'll try - but why the different behaviour? The windows
> native binary is "output".
>  Best wishes,
>  Roger
I have seen / heard / read that a make distclean can be of use-- but I
think that I spoke too soon. It is usually related to re-compiling
only portions of the source. Not sure what it could be.
Dylan
> > Cheers,
> > Dylan
> > >  Roger Bivand
> > >  Economic Geography Section, Department of Economics, Norwegian School
> of
> > >  Economics and Business Administration, Helleveien 30, N-5045 Bergen,
> > >  Norway. voice: +47 55 95 93 55; fax +47 55 95 95 43
> > >  e-mail: Roger.Bivand at nhh.no
> > >  _______________________________________________
> > >  grass-dev mailing list
> > >  grass-dev at lists.osgeo.org
> > >  http://lists.osgeo.org/mailman/listinfo/grass-dev
>  Roger Bivand
>  Economic Geography Section, Department of Economics, Norwegian School of
