[GRASS-dev] db commands on vectors stored in another mapset
Maciej Sieczka
tutey at o2.pl
Wed Apr 16 13:38:14 EDT 2008
Dylan Beaudette pisze:
> Is this the normal behavior? i.e. I can "use" raster and vector files
> across mapsets, but why not vector attributes?
Because you are using DBF driver and your database is in:
$GISDBASE/$LOCATION_NAME/$MAPSET/dbf/
(check with db.connect -p). This results in a different path from mapset
to mapset. I guess this is a feature.
In order to use db.select cross-mapset with DBF driver you need to set
database= explicitely.
Maciek
