[GRASS-dev] db commands on vectors stored in another mapset
Dylan Beaudette dylan.beaudette at gmail.com
Wed Apr 16 13:59:26 EDT 2008
On Wednesday 16 April 2008, Maciej Sieczka wrote:
> Dylan Beaudette pisze:
> > Is this the normal behavior? i.e. I can "use" raster and vector files
> > across mapsets, but why not vector attributes?
> Because you are using DBF driver and your database is in:
> $GISDBASE/$LOCATION_NAME/$MAPSET/dbf/
> (check with db.connect -p). This results in a different path from mapset
> to mapset. I guess this is a feature.
> In order to use db.select cross-mapset with DBF driver you need to set
> database= explicitely.
> Maciek
Thanks Maciek.
I see that the following works as expected:
# not logged into the 'PERMANENT' mapset
db.select bugsites database=/home/dylan/grass/spearfish60/PERMANENT/dbf/
I suppose that altering the behavior of the db.* commands would be dangerous,
and really should respect the current mapset's database connection.
How hard would it be to parse the @mapset, remove it in the actual SQL, but
pass it into the 'database' selection? Or more importantly, is there any way
to make typing 'database=/home/dylan/grass/spearfish60/PERMANENT/dbf/' any
less painfull?
Cheers,
Dylan
Dylan Beaudette
Soil Resource Laboratory
http://casoilresource.lawr.ucdavis.edu/
University of California at Davis
530.754.7341
