[GRASS-dev] [GRASS GIS] #128: NVIZ fails to load vector points
without other map
trac at osgeo.org
Wed Apr 16 17:14:15 EDT 2008
#128: NVIZ fails to load vector points without other map
Reporter: neteler | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: default | Version: svn-trunk
Keywords: tcl |
I hoped to load a 2D or a 3D points map into NVIZ (Lidar points). But it
crashes:
v.info -t lidar1map3d
nodes=37997
points=38008
lines=0
boundaries=0
centroids=0
areas=0
islands=0
faces=0
kernels=0
primitives=38008
map3d=1
v.out.ascii lidar1map3d |head -3
512743.63|5403547.33|308.68|1
512743.62|5403547.33|308.7|2
512743.61|5403547.33|308.72|3
nviz point=lidar1map3d
WARNING: Adapted sites library used for vector points (module should be
updated to GRASS 6 vector library).
Site dim: 3
Sites file lidar1map3d loaded.
Error in startup script: can't use non-numeric floating-point value as
operand of "*"
while executing
"expr int($curr * 1)"
(procedure "Nv_mkFloatScale" line 16)
invoked from within
"Nv_mkFloatScale $Nv_(HEIGHT_SLIDER) v height $max $min $val update_height
1"
(procedure "mk_hgt_slider" line 12)
invoked from within
"mk_hgt_slider $BASE.midf"
(procedure "mkmainPanel" line 143)
invoked from within
"mk$name\Panel $path"
invoked from within
"if [catch {set Nv_($path)}] {
set file panel_$name.tcl
set Nv_($path) [mk$name\Panel $path]
(procedure "Nv_force_panel" line 8)
invoked from within
"Nv_force_panel main"
(procedure "Nv_makeGUI" line 183)
invoked from within
"Nv_makeGUI .top"
(file "/home/neteler/grass63/dist.x86_64-unknown-linux-
gnu/etc/nviz2.2/scripts/nviz2.2_script" line 1046)
Markus
Ticket URL: <http://trac.osgeo.org/grass/ticket/128>
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
