Roger Bivand wrote: > have odd/stale things in the GRASS_LD_LIBRARY_PATH and in PATH (or LD > path) environment variables. I don't have ldd on Cygwin, but will look > under F7. On Cygwin, "cygcheck" lists the DLLs which a program uses. -- Glynn Clements <glynn at gclements.plus.com>
