[GRASS-dev] web svn
Glynn Clements
glynn at gclements.plus.com
Fri Apr 18 05:58:28 EDT 2008
Hamish wrote:
> any reason to retain the /trunk/ part of the grass-web SVN?
How else would you check out the trunk?
> Can we move the contents ../
If you did that, checking out https://svn.osgeo.org/grass/grass/ would
check out all of the branches and tags as subdirectories alongside the
code from the trunk.
> just like the grass-addons repo?
It's grass-addons which is wrong; AFAICT, there is no way to create
branches or tags for it.
