[GRASS-dev] web svn
Martin Landa
landa.martin at gmail.com
Fri Apr 18 08:46:36 EDT 2008
Hi well,
from my point of view would be the best SVN repo structure
grass/
/trunk
/grass
/addons
/web
/branches
/tags
Too late to change layout in this way.
Martin
2008/4/18, Glynn Clements <glynn at gclements.plus.com>:
> Hamish wrote:
> > any reason to retain the /trunk/ part of the grass-web SVN?
> How else would you check out the trunk?
> > Can we move the contents ../
> If you did that, checking out https://svn.osgeo.org/grass/grass/ would
> check out all of the branches and tags as subdirectories alongside the
> code from the trunk.
> > just like the grass-addons repo?
> It's grass-addons which is wrong; AFAICT, there is no way to create
> branches or tags for it.
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
