R: [GRASS-dev] 6.3.0 is out! please prepare binaries...
marco.pasetti at alice.it marco.pasetti at alice.it
Mon Apr 21 10:32:03 EDT 2008
Glynn,
that means that I should wait for an updated release tarball and rebuild?
shall I build from SVN trunk to check out that all is working correctly on Win?
that will take approx 3 hours, so, if I need to re-build from an unpadated tarball later, consider that the *SVN build check* would delay my binary release.
Marco
Da: grass-dev-bounces at lists.osgeo.org per conto di Glynn Clements
Inviato: lun 21/04/2008 16.16
A: Markus Neteler
Cc: GRASS developers list
Oggetto: Re: [GRASS-dev] 6.3.0 is out! please prepare binaries...
Markus Neteler wrote:
> Before making the big announcement, let's prepare
> binaries and the final release announcement.
Note: most of the imagery modules are missing in 6.3.0.
The reason is that changes to the way that SUBDIRS was handled in
imagery/Makefile resulted in most of the modules not being built. The
specific change in question is r30999.
Essentially, only the modules listed in $(FFTWBASED) and $(XMONBASED)
are actually built (assuming that FFTW and X11 respectively are
enabled). The modules which are supposed to be built unconditionally
are actually never built.
I have just committed a fix to the trunk (r31065), but all of the
6.3.0 binary packages which people have built will be missing the
following modules:
        i.ask
        i.atcorr
        i.cluster
        i.find
        i.gensig
        i.gensigset
        i.group
        i.his.rgb
        i.maxlik
        i.rectify
        i.rgb.his
        i.smap
        i.target
        i.pca
        i.cca
grass-dev mailing list
grass-dev at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20080421/ac0ea282/attachment.html
