[GRASS-dev] 6.3.0 is out! please prepare binaries...
Martin Landa
landa.martin at gmail.com
Mon Apr 21 12:20:59 EDT 2008
2008/4/21, Glynn Clements <glynn at gclements.plus.com>:
> Note: most of the imagery modules are missing in 6.3.0.
> The reason is that changes to the way that SUBDIRS was handled in
> imagery/Makefile resulted in most of the modules not being built. The
> specific change in question is r30999.
> Essentially, only the modules listed in $(FFTWBASED) and $(XMONBASED)
> are actually built (assuming that FFTW and X11 respectively are
> enabled). The modules which are supposed to be built unconditionally
> are actually never built.
> I have just committed a fix to the trunk (r31065), but all of the
> 6.3.0 binary packages which people have built will be missing the
> following modules:
> i.ask
> i.atcorr
> i.cluster
> i.find
> i.gensig
> i.gensigset
> i.group
> i.his.rgb
> i.maxlik
> i.rectify
> i.rgb.his
> i.smap
> i.target
> i.pca
> i.cca
very bad news after tagging 6.3.0, better to discover now then later,
thanks Glynn! I have backported fixed Makefile to releasebranch_6_3. I
am afraid we need to tag 6.3.0 again(?)
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
