[GRASS-dev] 6.3.0 is out! please prepare binaries...
Markus Neteler
neteler at osgeo.org
Mon Apr 21 12:29:15 EDT 2008
hi,
On Mon, Apr 21, 2008 at 6:20 PM, Martin Landa <landa.martin at gmail.com> wrote:
> 2008/4/21, Glynn Clements <glynn at gclements.plus.com>:
> > Note: most of the imagery modules are missing in 6.3.0.
> > The reason is that changes to the way that SUBDIRS was handled in
> > imagery/Makefile resulted in most of the modules not being built. The
> > specific change in question is r30999.
> > Essentially, only the modules listed in $(FFTWBASED) and $(XMONBASED)
> > are actually built (assuming that FFTW and X11 respectively are
> > enabled). The modules which are supposed to be built unconditionally
> > are actually never built.
> > I have just committed a fix to the trunk (r31065), but all of the
> > 6.3.0 binary packages which people have built will be missing the
> > following modules:
> > i.ask
> > i.atcorr
> > i.cluster
> > i.find
> > i.gensig
> > i.gensigset
> > i.group
> > i.his.rgb
> > i.maxlik
> > i.rectify
> > i.rgb.his
> > i.smap
> > i.target
> > i.pca
> > i.cca
> very bad news after tagging 6.3.0, better to discover now then later,
> thanks Glynn! I have backported fixed Makefile to releasebranch_6_3. I
> am afraid we need to tag 6.3.0 again(?)
*Can* we redo 6.3.0? Or go directly for 6.3.1?
Markus
