[GRASS-dev] 6.3.0 is out! please prepare binaries...
Wolf Bergenheim
wolf+grass at bergenheim.net
Mon Apr 21 12:43:03 EDT 2008
IMHO it should be called 6.3.1 since 6.3.0 was already released.
In SVN tags act exactly as branches, so in principle we could simply
checkout the tag and commit.
--Wolf
On 21.04.2008 19:29, Markus Neteler wrote:
> hi,
> On Mon, Apr 21, 2008 at 6:20 PM, Martin Landa <landa.martin at gmail.com> wrote:
>> 2008/4/21, Glynn Clements <glynn at gclements.plus.com>:
>>> Note: most of the imagery modules are missing in 6.3.0.
>> > The reason is that changes to the way that SUBDIRS was handled in
>> > imagery/Makefile resulted in most of the modules not being built. The
>> > specific change in question is r30999.
>> > Essentially, only the modules listed in $(FFTWBASED) and $(XMONBASED)
>> > are actually built (assuming that FFTW and X11 respectively are
>> > enabled). The modules which are supposed to be built unconditionally
>> > are actually never built.
>> > I have just committed a fix to the trunk (r31065), but all of the
>> > 6.3.0 binary packages which people have built will be missing the
>> > following modules:
>> > i.ask
>> > i.atcorr
>> > i.cluster
>> > i.find
>> > i.gensig
>> > i.gensigset
>> > i.group
>> > i.his.rgb
>> > i.maxlik
>> > i.rectify
>> > i.rgb.his
>> > i.smap
>> > i.target
>> > i.pca
>> > i.cca
>> very bad news after tagging 6.3.0, better to discover now then later,
>> thanks Glynn! I have backported fixed Makefile to releasebranch_6_3. I
>> am afraid we need to tag 6.3.0 again(?)
> *Can* we redo 6.3.0? Or go directly for 6.3.1?
> Markus
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
<:3 )---- Wolf Bergenheim ----( 8:>
