[GRASS-dev] 6.3.0 is out! please prepare binaries...
Glynn Clements
glynn at gclements.plus.com
Tue Apr 22 01:29:38 EDT 2008
Hamish wrote:
> > Note: most of the imagery modules are missing in 6.3.0.
> yikes. thank you for spotting this before the official announcement
> Glynn, really.
> lesson 1: Hamish needs to test his Makefile changes with a full clean
That only helps if you actually check that everything which is
supposed to exist actually does so. The change didn't result in any
visible errors; a bunch of modules just didn't get compiled.
I only spotted it because I looked into this:
[GRASS GIS] #133: Unable to create file [REF] for subgroup
and discovered that i.group didn't actually exist.
[Then something distracted me, and I forgot to commit or otherwise
follow up on the Makefile changes until "svn status" reminded me that
I had changed that file.]
