[GRASS-dev] Linking gdal 1.5.1 in mingw
Joel Pitt joel.pitt at gmail.com
Tue Apr 22 04:54:56 EDT 2008
Hi all,
I've struggled with this for most of today, so thought see if anyone
here had any clues to my troubles.
I'm following the below guide to compile GRASS and related libraries
from scratch on Windows using MinGW:
http://www.webalice.it/marco.pasetti/grass/BuildFromSource.html
I've gotten up to compiling GDAL, but it doesn't link... saying:
libtool: link: g++ -shared -nostdlib
C:/msys/mingw/bin/../lib/gcc/mingw32/3.4.5/../../../dllcrt2.o
C:/msys/mingw/bin/../lib/gcc/mingw32/3.4.5/crtbegin.o
.libs/libgdal.la.lnkscript  -L/usr/local/lib
/usr/local/lib/libgeos_c.dll.a /usr/local/lib/libgeos.dll.a
-L/usr/local/sqlite/lib /usr/local/sqlite/lib/libsqlite3.dll.a
-LC:/msys/local/pgsql/lib -lpq
-LC:/msys/mingw/bin/../lib/gcc/mingw32/3.4.5
-LC:/msys/mingw/bin/../lib/gcc/mingw32/3.4.5/../../../../mingw32/lib
-LC:/msys/mingw/bin/../lib/gcc/mingw32/3.4.5/../../.. -lstdc++
-lmingw32 -lgcc -lmoldname -lmingwex -lmsvcrt -luser32 -lkernel32
-ladvapi32 -lshell32 -lmingw32 -lgcc -lmoldname -lmingwex -lmsvcrt
C:/msys/mingw/bin/../lib/gcc/mingw32/3.4.5/crtend.o       -o
.libs/libgdal-1.dll -Wl,--enable-auto-image-base -Xlinker --out-implib
-Xlinker .libs/libgdal.dll.a
C:\msys\mingw\bin\..\lib\gcc\mingw32\3.4.5\..\..\..\..\mingw32\bin\ld.exe:
cannot find /usr/local/src/gdal-1.5.1/ogr/ogrsf_frmts/o/.libs/arraylist.o
collect2: ld returned 1 exit status
make[1]: *** [libgdal.la] Error 1
make[1]: Leaving directory `/usr/local/src/gdal-1.5.1'
make: *** [check-lib] Error 2
When I check for the missing file,
/usr/local/src/gdal-1.5.1/ogr/ogrsf_frmts/o/.libs/arraylist.o seems to
be sitting there with appropriate permissions and all.
Looking around, alot of the GDAL compilation guides say to configure
using "--without-libtool" but that just results in lots of undefined
references.
Has any one successfully compiled GDAL 1.5.1 using the above guide?
Thanks in advance for any help,
J
