R: [GRASS-dev] Linking gdal 1.5.1 in mingw
marco.pasetti at alice.it
Tue Apr 22 05:02:52 EDT 2008
Hi Joel,
>Has any one successfully compiled GDAL 1.5.1 using the above guide?
yes, sure, I never publish anything if I don't check it's actually working ;-)
did you hacked gdal-1.5.1\GNUmakefile?
Marco Pasetti
Da: grass-dev-bounces at lists.osgeo.org per conto di Joel Pitt
Inviato: mar 22/04/2008 10.54
A: Grass Developers List
Oggetto: [GRASS-dev] Linking gdal 1.5.1 in mingw
Hi all,
I've struggled with this for most of today, so thought see if anyone
here had any clues to my troubles.
I'm following the below guide to compile GRASS and related libraries
from scratch on Windows using MinGW:
http://www.webalice.it/marco.pasetti/grass/BuildFromSource.html
I've gotten up to compiling GDAL, but it doesn't link... saying:
libtool: link: g++ -shared -nostdlib
C:/msys/mingw/bin/../lib/gcc/mingw32/3.4.5/../../../dllcrt2.o
C:/msys/mingw/bin/../lib/gcc/mingw32/3.4.5/crtbegin.o
.libs/libgdal.la.lnkscript -L/usr/local/lib
/usr/local/lib/libgeos_c.dll.a /usr/local/lib/libgeos.dll.a
-L/usr/local/sqlite/lib /usr/local/sqlite/lib/libsqlite3.dll.a
-LC:/msys/local/pgsql/lib -lpq
-LC:/msys/mingw/bin/../lib/gcc/mingw32/3.4.5
-LC:/msys/mingw/bin/../lib/gcc/mingw32/3.4.5/../../../../mingw32/lib
-LC:/msys/mingw/bin/../lib/gcc/mingw32/3.4.5/../../.. -lstdc++
-lmingw32 -lgcc -lmoldname -lmingwex -lmsvcrt -luser32 -lkernel32
-ladvapi32 -lshell32 -lmingw32 -lgcc -lmoldname -lmingwex -lmsvcrt
C:/msys/mingw/bin/../lib/gcc/mingw32/3.4.5/crtend.o -o
.libs/libgdal-1.dll -Wl,--enable-auto-image-base -Xlinker --out-implib
-Xlinker .libs/libgdal.dll.a
C:\msys\mingw\bin\..\lib\gcc\mingw32\3.4.5\..\..\..\..\mingw32\bin\ld.exe:
cannot find /usr/local/src/gdal-1.5.1/ogr/ogrsf_frmts/o/.libs/arraylist.o
collect2: ld returned 1 exit status
make[1]: *** [libgdal.la] Error 1
make[1]: Leaving directory `/usr/local/src/gdal-1.5.1'
make: *** [check-lib] Error 2
When I check for the missing file,
/usr/local/src/gdal-1.5.1/ogr/ogrsf_frmts/o/.libs/arraylist.o seems to
be sitting there with appropriate permissions and all.
Looking around, alot of the GDAL compilation guides say to configure
using "--without-libtool" but that just results in lots of undefined
references.
Thanks in advance for any help,
J
grass-dev mailing list
grass-dev at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20080422/ef8eab2c/attachment.html
