[GRASS-dev] SVN version number
Martin Landa
landa.martin at gmail.com
Thu Apr 24 06:18:18 EDT 2008
2008/4/24, Paul Kelly <paul-grass at stjohnspoint.co.uk>:
> Updating from SVN this morning I see that the version number is now 6.4.svn
> - I'm not sure if that's right? I thought it should be 6.3.svn until a
> release branch for 6.4 is created, and the version number on that branch
> will be 6.4.svn. At that point the version on develbranch_6, which will be
> in operation by then, will become 6.5.svn (although there might not ever be
> any 6.5 releases, similar to 5.5).
Since 6.3.0 is out we can create 'develbranch_6' branch, e.g. during
this weekend (as 6.4svn). After creating 'releasebranch_6_4' (as
6.4svn) it can be renamed to 6.5svn. Trunk becomes 7.0svn. Does it
make sense to you?
Martin
> It is all a bit confusing though since we've started partially abandoning
> the odd-development/stable-release system.
> Any thoughts?
> Paul
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
