[GRASS-dev] GSoC, reimplementation of modules v.voronoi and v.delaunay
Paul Kelly paul-grass at stjohnspoint.co.uk
Thu Apr 24 07:59:47 EDT 2008
On Thu, 24 Apr 2008, Wolf Bergenheim wrote:
> On 24.04.2008 10:54, Martin Pavlovsky wrote:
>> Thank you for the warm welcome.
>> I think that having only one module has many advantages in different
>> perspectives. Since VD and DT are so closely related, I presume that more
>> than 70% of the code would be very similar for both modules if they were
>> separated. This replication would be avoided by joining them together. The
>> relationship between VD and DT would be more obvious for the user if there
>> was a single module named "v.voronoi_delaunay" or sth similar. User will
>> choose VD or DT by setting parameters, it seems to me as the most natural
>> way. This DT -> VD and VD -> DT conversion is very important feature which
>> is lacking in current implementation, I am all for it. One disadvantage of
>> having only one module might be slightly steeper learning curve, but I
>> don't see it as a major obstacle.
> I agree. It is better to have it as one module. I wonder what would be a good
> name. v.voronoi.delauny seems a bit awkward but very obvious. I can't think
> of a better name. Anybody else have some idea?
> Another way to handle it would be to make two modules, but re-use that 70% by
> having it in a library or something.
The idea of a library for shared code appeals to me more - I suspect we'd
end up creating wrapper scripts called v.voronoi and v.delaunay that would
call the combined module with appropriate options anyway, in order to
simplify things from a user perspective as has been done already e.g. with
v.centroids as a wrapper for v.category.
If we go with the library option, it would be a static library that could
be linked into both modules. Suggested directory layout: a new directory
under vector/ to contain everything, e.g. call it "geometric" or "vordel"
or something - then subdirectories lib, v.voronoi and v.delaunay. Perhaps
something similar to what has been done for vector/v.lrs/ - but I think
the subdirectory there should have been called simply lrs - it's confusing
as there's no module called v.lrs - and I don't think the library should
be a normal shared GRASS library installed with all the others, as has
been done there - static is just fine in this case.
The connection between Delaunay triangulation and Voronoi tessellation
could be made very clear in the man pages / documentation for both modules
anyway.
That's what I think but it's Martin's project!
Paul
