[GRASS-dev] GRASS 7 development started
Hamish
hamish_b at yahoo.com
Mon Apr 28 17:55:28 EDT 2008
Glynn wrote:
> Can we finalise the coding style, so that we can apply it?
> This should be done before we start making substantial changes. Once
> the code has been re-formatted, it will become much harder to compare
> "before" and "after" versions, as any such diff will be dominated by
> the formatting changes.
> My personal preference is:
> indent -bad -bap -bbb -bl -bli0 -bls -cli0 -cs -fc1 -hnl -i4 -l79 \
> -nbbo -nbc -nbfda -nbfde -ncdb -ncdw -nce -nfca -npcs -nprs \
> -npsl -nsc -nsob -saf -sai -saw -sbi0 -ss -ts8 -ut
> Descriptions of the above options are given below, although it may be
> more clear to just apply the above command to a bunch of files and
> look at them.
> Others will presumably have different preferences; in which case
> please express them sooner rather than later.
> The precise style doesn't really matter[1]; what DOES matter is that
> we have one style for all of GRASS, and that everyone abides by it[2].
> [1] Except for -ts8, which isn't a stylistic choice but a file format
> issue. Using something other than -ts8 is irrational; the only other
> sane alternative is to just forbid tabs outright (-nut, --no-tabs).
> This is particularly important for Python code, where indentation is
> syntatic, not just stylistic. I would suggest using "python -t -t ..."
> to catch this.
> [2] The main advantage of 7.x is the ability to make incompatible API
> changes. Any such changes will typically require changing files across
> large numbers of modules. Expecting developers to modify their text
> editor's formatting settings from one file to the next (because
> different files have different formatting) is unacceptable, IMHO.
> Descriptions of the above options:
> -bad, --blank-lines-after-declarations
> Force blank lines after the declarations.
> -bap, --blank-lines-after-procedures
> Force blank lines after procedure bodies.
> -bbb, --blank-lines-before-block-comments
> Force blank lines before block comments.
> -bl, --braces-after-if-line
> Put braces on line after if, etc.
> -blin, --brace-indentn
> Indent braces n spaces.
> -bls, --braces-after-struct-decl-line
> Put braces on the line after struct declaration lines.
> -clin, --case-indentationn
> Case label indent of n spaces.
> -cs, --space-after-cast
> Put a space after a cast operator.
> -fc1, --format-first-column-comments
> Format comments in the first column.
> -hnl, --honour-newlines
> Prefer to break long lines at the position of newlines
> in the
> input.
> -in, --indent-leveln
> Set indentation level to n spaces.
> -ln, --line-lengthn
> Set maximum line length for non-comment lines to n.
> -nbbo, --break-after-boolean-operator
> Do not prefer to break long lines before boolean operators.
> -nbc, --no-blank-lines-after-commas
> Do not force newlines after commas in declarations.
> -nbfda, --dont-break-function-decl-args
> Don't put each argument in a function declaration on a
> seperate
> line.
> -nbfde, --dont-break-function-decl-args
> Break the line after the last argument in a declaration.
> -ncdb, --no-comment-delimiters-on-blank-lines
> Do not put comment delimiters on blank lines.
> -ncdw, --dont-cuddle-do-while
> Do not cuddle } and the while of a do {} while;.
> -nce, --dont-cuddle-else
> Do not cuddle } and else.
> -nfca, --dont-format-comments
> Do not format any comments.
> -npcs, --no-space-after-function-call-names
> Do not put space after the function in function calls.
> -nprs, --no-space-after-parentheses
> Do not put a space after every '(' and before every ')'.
> -npsl, --dont-break-procedure-type
> Put the type of a procedure on the same line as its name.
> -nsc, --dont-star-comments
> Do not put the `*' character at the left of comments.
> -nsob, --leave-optional-blank-lines
> Do not swallow optional blank lines.
> -saf, --space-after-for
> Put a space after each for.
> -sai, --space-after-if
> Put a space after each if.
> -saw, --space-after-while
> Put a space after each while.
> -sbin, --struct-brace-indentationn
> Indent braces of a struct, union or enum N spaces.
> -ss, --space-special-semicolon
> On one-line for and while statments, force a blank before
> the semi-
> colon.
> -tsn, --tab-sizen
> Set tab size to n spaces.
> -ut, --use-tabs
> Use tabs. This is the default.
FWIW this is how those rules differ from what is currently given in the
SUBMITTING file and what is at
http://grass.osgeo.org/wiki/Development#Explanation_of_C_indentation_rules
--- submitting 2008-04-29 09:45:35.000000000 +1200
+++ glynn 2008-04-29 09:45:47.000000000 +1200
@@ -1,33 +1,32 @@
+ -bad
-bap
-bbb
- -bli1
+ -bl
+ -bli0
-bls
- -br
- -cbi0
- -ci4
-cli0
- -d0
- -di0
+ -cs
-fc1
-hnl
-i4
- -ip4
- -l80
- -lc80
- -lp
- -nbad
+ -l79
-nbbo
-nbc
+ -nbfda
+ -nbfde
-ncdb
+ -ncdw
-nce
- -ncs
-nfca
-npcs
-nprs
-npsl
+ -nsc
-nsob
- -pi4
+ -saf
+ -sai
+ -saw
-sbi0
- -sc
-ss
-ts8
+ -ut
Hamish
____________________________________________________________________________________
Be a better friend, newshound, and
know-it-all with Yahoo! Mobile. Try it now. http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
