[GRASS-dev] new grass add-on
Markus Neteler
neteler at osgeo.org
Tue Apr 29 15:30:10 EDT 2008
Hi Roberto,
On Tue, Apr 29, 2008 at 12:01 PM, roberto.marzocchi
<roberto.marzocchi at gmail.com> wrote:
> Hello,
> I want submitt a new raster script in the grassaddons.
> The raster command name is r.inund.fluv.
This is great!
> This command allows to obtain a fluvial potentially inundation map given a
> high-resolution DTM of the area surrounding the river and a water surface
> profile calculated through an 1-D hydrodinamic model.
> For more inundation see the r.inund.fluv.html file into the r.inund.fluv
> folder.
> Only one question... I've a osgeo_id and I've made the dowload and
> installed the TortoiseSVN program .
> How can I put my folder into the
> https://svn.osgeo.org/grass/grass-addons/raster ?
The procedure to obtain write access to the GRASS Addons SVN
is explained here:
http://trac.osgeo.org/grass/wiki/HowToContribute
-> Procedure to request GRASS-SVN write access
-> GRASS-Addons-SVN repository
Please take a look there and submit the needed info to me
or another developer.
Markus
