[GRASS-dev] new grass add-on
roberto.marzocchi roberto.marzocchi at gmail.com
Wed Apr 30 05:23:03 EDT 2008
I've a problem using the GRASS Addons subversion.
I made a checkout of grass-addons folder, then I add a new folder
(grass-addons/raster/r.inund.fluv).
And then I've a problem when I try to commit the grass-addons folder.
The message error  is  this:
"/Error: Commit failed (details follow):
 Error: MKACTIVITY of
'/grass/!svn/act/3b53eff3-320e-324f-b2ae-62f27863c1e6': 403 Forbidden
(https://svn.osgeo.org)"/
Anyone has an idea of error?
Thanks in advanced
Roberto
Markus Neteler ha scritto:
> Hi  Roberto,
> On Tue, Apr 29, 2008 at 12:01 PM, roberto.marzocchi
> <roberto.marzocchi a gmail.com> wrote:
>> Hello,
>>  I  want submitt a new raster script  in  the grassaddons.
>>  The raster command  name is  r.inund.fluv.
> This is great!
>> This command allows to obtain a fluvial potentially inundation map given a
>> high-resolution DTM of the area surrounding the river and a water surface
>> profile calculated through an 1-D hydrodinamic model.
>>  For more inundation see the r.inund.fluv.html file into the r.inund.fluv
>> folder.
>>  Only one question... I've a osgeo_id and I've made the dowload and
>> installed  the  TortoiseSVN program .
>>  How can I put my folder into the
>> https://svn.osgeo.org/grass/grass-addons/raster ?
> The procedure to obtain write access to the GRASS Addons SVN
> is explained here:
>  http://trac.osgeo.org/grass/wiki/HowToContribute
>  -> Procedure to request GRASS-SVN write access
>     -> GRASS-Addons-SVN repository
> Please take a look there and submit the needed info to me
> or another developer.
> Markus
Un allegato HTML ? stato rimosso...
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20080430/d2a2f744/attachment.html
