[GRASS-dev] new grass add-on
Moritz Lennert
mlennert at club.worldonline.be
Wed Apr 30 08:26:17 EDT 2008
On 30/04/08 11:23, roberto.marzocchi wrote:
> I've a problem using the GRASS Addons subversion.
> I made a checkout of grass-addons folder, then I add a new folder
> (grass-addons/raster/r.inund.fluv).
> And then I've a problem when I try to commit the grass-addons folder.
> The message error is this:
> "/Error: Commit failed (details follow):
> Error: MKACTIVITY of
> '/grass/!svn/act/3b53eff3-320e-324f-b2ae-62f27863c1e6': 403 Forbidden
> (https://svn.osgeo.org)"/
> Anyone has an idea of error?
Did you submit with your login and the entered your password ? See
http://trac.osgeo.org/grass/wiki/DownloadSource
-> Committing code to SVN (developers with write access)
Moritz
> Thanks in advanced
> Roberto
> Markus Neteler ha scritto:
>> Hi Roberto,
>> On Tue, Apr 29, 2008 at 12:01 PM, roberto.marzocchi
>> <roberto.marzocchi at gmail.com> wrote:
>>> Hello,
>>> I want submitt a new raster script in the grassaddons.
>>> The raster command name is r.inund.fluv.
>> This is great!
>>> This command allows to obtain a fluvial potentially inundation map given a
>>> high-resolution DTM of the area surrounding the river and a water surface
>>> profile calculated through an 1-D hydrodinamic model.
>>> For more inundation see the r.inund.fluv.html file into the r.inund.fluv
>>> folder.
>>> Only one question... I've a osgeo_id and I've made the dowload and
>>> installed the TortoiseSVN program .
>>> How can I put my folder into the
>>> https://svn.osgeo.org/grass/grass-addons/raster ?
>> The procedure to obtain write access to the GRASS Addons SVN
>> is explained here:
>> http://trac.osgeo.org/grass/wiki/HowToContribute
>> -> Procedure to request GRASS-SVN write access
>> -> GRASS-Addons-SVN repository
>> Please take a look there and submit the needed info to me
>> or another developer.
>> Markus
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
