[GRASS-dev] new grass add-on
roberto.marzocchi
roberto.marzocchi at gmail.com
Wed Apr 30 09:14:23 EDT 2008
Maybe my osgeo id isn't available for grass????
http://svn.osgeo.org/grass/grass-addons/contributors.csv
Thanks for your help!
R
Moritz Lennert ha scritto:
> On 30/04/08 11:23, roberto.marzocchi wrote:
>> I've a problem using the GRASS Addons subversion.
>> I made a checkout of grass-addons folder, then I add a new folder
>> (grass-addons/raster/r.inund.fluv).
>> And then I've a problem when I try to commit the grass-addons folder.
>> The message error is this:
>> "/Error: Commit failed (details follow): Error: MKACTIVITY of
>> '/grass/!svn/act/3b53eff3-320e-324f-b2ae-62f27863c1e6': 403 Forbidden
>> (https://svn.osgeo.org)"/
>> Anyone has an idea of error?
> Did you submit with your login and the entered your password ? See
> http://trac.osgeo.org/grass/wiki/DownloadSource
> -> Committing code to SVN (developers with write access)
> Moritz
>> Thanks in advanced
>> Roberto
>> Markus Neteler ha scritto:
>>> Hi Roberto,
>>> On Tue, Apr 29, 2008 at 12:01 PM, roberto.marzocchi
>>> <roberto.marzocchi a gmail.com> wrote:
>>>> Hello,
>>>> I want submitt a new raster script in the grassaddons.
>>>> The raster command name is r.inund.fluv.
>>> This is great!
>>>> This command allows to obtain a fluvial potentially inundation map
>>>> given a
>>>> high-resolution DTM of the area surrounding the river and a water
>>>> surface
>>>> profile calculated through an 1-D hydrodinamic model.
>>>> For more inundation see the r.inund.fluv.html file into the
>>>> r.inund.fluv
>>>> folder.
>>>> Only one question... I've a osgeo_id and I've made the dowload and
>>>> installed the TortoiseSVN program .
>>>> How can I put my folder into the
>>>> https://svn.osgeo.org/grass/grass-addons/raster ?
>>> The procedure to obtain write access to the GRASS Addons SVN
>>> is explained here:
>>> http://trac.osgeo.org/grass/wiki/HowToContribute
>>> -> Procedure to request GRASS-SVN write access
>>> -> GRASS-Addons-SVN repository
>>> Please take a look there and submit the needed info to me
>>> or another developer.
>>> Markus
>> grass-dev mailing list
>> grass-dev a lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
