Hi, I'm trying to figure out a way to find the cat value of a node. Using Vect_get_line_nodes() returns the ids of the initial and end node of a line. However, these ids are not the cat values of those nodes. I've looked into Vect_cat_get() but this function returns the first category value from the layer. Any ideas? Thanks, Jaime
