[GRASS-dev] getting cat value of node
Martin Landa landa.martin at gmail.com
Wed Apr 30 13:31:54 EDT 2008
2008/4/30 Jaime Carrera <jaime.carrerah at gmail.com>:
>  I'm trying to figure out a way to find the cat value of a node. Using
>  Vect_get_line_nodes() returns the ids of the initial and end node of a
>  line. However, these ids are not the cat values of those nodes. I've
>  looked into Vect_cat_get() but this function returns the first
>  category value from the layer. Any ideas?
AFAIK category value can be assigned only to the simple features like
points, lines, boundaries, centroids, faces or kernels. Assigning
category value to node (vertex) is not currently supported. Workaround
can be to create additional vector point layer derived from nodes
(v.to.points -n).
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
