[GRASS-dev] viewshed and iostream issues
Michael Barton
michael.barton at asu.edu
Tue Aug 5 23:44:28 EDT 2008
On Aug 5, 2008, at 7:34 PM, <grass-dev-request at lists.osgeo.org> wrote:
> From: Laura Toma <ltoma at bowdoin.edu>
> Date: August 5, 2008 7:34:15 PM GMT-07:00
> To: Paul Kelly <paul-grass at stjohnspoint.co.uk>, grass-dev at lists.osgeo.org
> Cc: Will <willster3021 at gmail.com>
> Subject: [GRASS-dev] viewshed and iostream issues
> Viewshed does not immediately compile with the iostream library in
> grass. Over the last years there were a few changes to it, but
> were never merged them into the grass trunk because they did not
> seem important enough at the time. Now that both viewshed and
> terraflow use the same library, I don't think that it makes sense
> to try to make viewshed compile with an older version; instead, I
> would rather update the library. I looked over the grass svn
> logs and the only significant changes to iostream that I could see
> are the following:
> 1. #ifdef __MINGW32__ (windows compatibility)
> 2. char* replaced with std::string (Andy Danner's patch a few weeks
> ago)
> (is there anything else?)
> I have merged these changes into my most recent version of iostream,
> which I am attaching; it is split into headers
> (include_iostream.tar), and cc files (lib_iostream.tar). If you
> place them into grass_trunk/include/iostream/ and grass_trunk/lib/
> iostream/ respectively, the library, terraflow and viewshed all
> compile and run (macosx 10.4).
> This is a start to get r.viewshed to compile and run and get some
> feedback. If the general opinion is to keep the library
> unchanged, I guess we'll have to modify viewshed, which is doable,
> though not particularly exciting.
> -Laura
Laura, Will, and Paul,
I'm very much looking forward to being able to test out this new module.
Michael
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20080805/c910e01b/attachment.html
