r.support [was: Re: [GRASS-dev] Re: 7.x Status Update (Glynn
Clements)]
Glynn Clements
glynn at gclements.plus.com
Thu Aug 7 17:33:05 EDT 2008
Markus Neteler wrote:
> >>> **r.support - Need some way to access raster metadata.
> >> Of the four sub-modules:
> >> modhead -> r.region
> >> modcats -> r.category
> >> modcolr -> r.colors
> >> modhist -> ???
> >> The functionality built into the front-end module is mostly
> >> non-interactive, and can be cannibalised.
> >> So that just leaves editing the history. The obvious non-interactive
> >> solution is a module (or two) which allows the history to be read from
> >> or written to a text file.
> > r.support already allows non-interactive editing of most of the meta-data,
> > including history (r.support map history="xyz"), so wouldn't it be enought
> > to "just" disable the interactive functionality ?
> modhist -> metadata
> It's fundamental to maintain at a minimal level (this needs to be improved)
> metadata of maps. Don't remove, please (the cmd line version).
I have salvaged the non-interactive portions of r.support.
It has three new flags to replace certain interactive yes/no prompts:
-s Update statistics (histogram, range)
-n Create/reset the null file
-d Delete the null file
I'll look into importing/exporting the history next.
