[GRASS-dev] 7.x Status Update
Moritz Lennert mlennert at club.worldonline.be
Sat Aug 9 09:11:51 EDT 2008
On 09/08/08 09:08, Glynn Clements wrote:
> Another potentially disruptive update: the raster library now uses
> floating point values for coordinates.
> Please help test d.* modules. With 120 modified files, the chances
> that I managed to break something are relatively high.
There seems to be a problem with d.vect. Area fill varies according to
zoom level. When you display an entire map (e.g. census_wake2000 in the
NC demo data set), a lot of areas are not filled, and there are empty
spaces between areas. Zooming in reduces the non-filled and empty areas
until they seem to disappear when you zoom in really far.
Moritz
