[GRASS-dev] 7.x Status Update
Glynn Clements
glynn at gclements.plus.com
Sat Aug 9 16:31:36 EDT 2008
Moritz Lennert wrote:
> > Another potentially disruptive update: the raster library now uses
> > floating point values for coordinates.
> > Please help test d.* modules. With 120 modified files, the chances
> > that I managed to break something are relatively high.
> There seems to be a problem with d.vect. Area fill varies according to
> zoom level. When you display an entire map (e.g. census_wake2000 in the
> NC demo data set), a lot of areas are not filled, and there are empty
> spaces between areas. Zooming in reduces the non-filled and empty areas
> until they seem to disappear when you zoom in really far.
I'll try to look into that later (the NC data set is 135MiB).
Does changing the render= option have any effect? I changed the
default from render=c to render=l, so this may suggest a bug in that
particular rendering mode (l should be more efficient, but it had
problems with XDRIVER).
