[GRASS-dev] 7.x Status Update
Sat Aug 9 21:02:08 EDT 2008
Moritz Lennert wrote:
> There seems to be a problem with d.vect. Area fill varies according to
> zoom level. When you display an entire map (e.g. census_wake2000 in the
> NC demo data set), a lot of areas are not filled, and there are empty
> spaces between areas. Zooming in reduces the non-filled and empty areas
> until they seem to disappear when you zoom in really far.
This should be fixed by r32659.
