[GRASS-dev] 7.x Status Update
Moritz Lennert
mlennert at club.worldonline.be
Sat Aug 9 22:12:45 EDT 2008
On 10/08/08 03:02, Glynn Clements wrote:
> Moritz Lennert wrote:
>> There seems to be a problem with d.vect. Area fill varies according to
>> zoom level. When you display an entire map (e.g. census_wake2000 in the
>> NC demo data set), a lot of areas are not filled, and there are empty
>> spaces between areas. Zooming in reduces the non-filled and empty areas
>> until they seem to disappear when you zoom in really far.
> This should be fixed by r32659.
Yep, rapid testing indicates that it is fixed.
Moritz
