[GRASS-dev] iostream lib and r.terraflow/r.viewshed
Maciej Sieczka
tutey at o2.pl
Sat Aug 9 15:14:41 EDT 2008
Paul Kelly pisze:
> r.terraflow still compiles fine so I hope there will be no unforeseen
> consequences.
In the current develbranch6 (r32655) there are 2 errors at the build time:
in lib/iostream:
$ make
c++
-I/home/shoofi/src/straight/grass64/dist.x86_64-unknown-linux-gnu/include
-pipe -march=core2 -g -Wall -D_FILE_OFFSET_BITS=64
-DPACKAGE=\""grasslibs"\"
-o OBJ.x86_64-unknown-linux-gnu/ami_stream.o -c ami_stream.cc
In file included from ami_stream.cc:29:
/home/shoofi/src/straight/grass64/dist.x86_64-unknown-linux-gnu/include/grass/iostream/ami_stream.h:
In constructor 'AMI_STREAM<T>::AMI_STREAM(const char*, AMI_stream_type)':
/home/shoofi/src/straight/grass64/dist.x86_64-unknown-linux-gnu/include/grass/iostream/ami_stream.h:256:
error: there are no arguments to 'strcpy' that depend on a template
parameter, so a declaration of 'strcpy' must be available
error: (if you use '-fpermissive', G++ will accept your code, but
allowing the use of an undeclared name is deprecated)
In member function 'AMI_err AMI_STREAM<T>::name(char**)':
/home/shoofi/src/straight/grass64/dist.x86_64-unknown-linux-gnu/include/grass/iostream/ami_stream.h:373:
error: there are no arguments to 'strlen' that depend on a template
parameter, so a declaration of 'strlen' must be available
/home/shoofi/src/straight/grass64/dist.x86_64-unknown-linux-gnu/include/grass/iostream/ami_stream.h:374:
ami_stream.cc: At global scope:
ami_stream.cc:46: warning: deprecated conversion from string constant to
'char*'
'char*'
'char*'
'char*'
'char*'
'char*'
'char*'
'char*'
'char*'
'char*'
'char*'
'char*'
'char*'
make: *** [OBJ.x86_64-unknown-linux-gnu/ami_stream.o] Error 1
in raster/r.terraflow:
$ make
c++ -c
-pipe -march=core2 -g -Wall -DUSER=\"shoofi\" -DNODATA_FIX
-D_FILE_OFFSET_BITS=64 -DPACKAGE=\""grassmods"\" -DELEV_FLOAT
common.cc -o OBJ.x86_64-unknown-linux-gnu/FLOAT/common.o
/home/shoofi/src/straight/grass64/dist.x86_64-unknown-linux-gnu/include/grass/iostream/ami.h:27,
from common.h:27,
from common.cc:35:
/home/shoofi/src/straight/grass64/dist.x86_64-unknown-linux-gnu/include/grass/iostream/ami_sort_impl.h:25,
from
/home/shoofi/src/straight/grass64/dist.x86_64-unknown-linux-gnu/include/grass/iostream/ami_sort.h:23,
from
/home/shoofi/src/straight/grass64/dist.x86_64-unknown-linux-gnu/include/grass/iostream/ami.h:33,
from common.h:27,
from common.cc:35:
/home/shoofi/src/straight/grass64/dist.x86_64-unknown-linux-gnu/include/grass/iostream/mem_stream.h:
In member function 'AMI_err MEM_STREAM<T>::name(char**)':
/home/shoofi/src/straight/grass64/dist.x86_64-unknown-linux-gnu/include/grass/iostream/mem_stream.h:90:
/home/shoofi/src/straight/grass64/dist.x86_64-unknown-linux-gnu/include/grass/iostream/mem_stream.h:91:
make: *** [OBJ.x86_64-unknown-linux-gnu/FLOAT/common.o] Error 1
Maciek
Maciej Sieczka
www.sieczka.org
