[GRASS-dev] Re: [GRASS GIS] #254: wxpython Layer Manager: higher
raster hides the lower
trac at osgeo.org
Tue Aug 12 12:05:15 EDT 2008
#254: wxpython Layer Manager: higher raster hides the lower
Reporter: giohappy | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: closed
Priority: critical | Milestone: 6.4.0
Component: wxGUI | Version: svn-develbranch6
Resolution: fixed | Keywords:
Platform: Linux | Cpu: x86-32
Changes (by cmbarton):
* status: new => closed
* version: svn-trunk => svn-develbranch6
* resolution: => fixed
Comment:
I just checked this in GRASS 6.4 updated from the svn last night and it
works fine. See the attached file.
Make sure that overlay is checked either in the properties dialog for the
upper raster file or in the preferences settings.
Your track ticket suggests that you are working with an older version. SVN
trunk now produces GRASS 7 (and a lot is broken due to heavy development).
GRASS 6.4 is now retrieved from develbranch_6. There were some issues with
this awhile back, but they were recently fixed.
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/254#comment:1>
